Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Ferramentas utilizadas neste teardown
Introdução
This break down will enable you to dismantle your ipod nano 1st generation without breaking it.
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua iPod Nano 1st Generation, use o nosso manual de serviço.
  1. 1.    Using an ipod unclipping tool (which could be a knife or similar to it), unclip the outer casing by putting the tool into the connection point. This should pop the case off. Note that force will need to be used. 1.    Using an ipod unclipping tool (which could be a knife or similar to it), unclip the outer casing by putting the tool into the connection point. This should pop the case off. Note that force will need to be used.
    • 1. Using an ipod unclipping tool (which could be a knife or similar to it), unclip the outer casing by putting the tool into the connection point. This should pop the case off. Note that force will need to be used.
  2. 2.    Remove the circuit board by unscrewing the 3 screws that hold it down. Note that specialised screwdrivers may need to be used.
    • 2. Remove the circuit board by unscrewing the 3 screws that hold it down. Note that specialised screwdrivers may need to be used.
  3. Kit de pontas universal para chave
    112 bits for every fix.
    Upgrade Your Toolbox
  4. 3.    Remove battery by carefully detaching the connect wire that’s connected to the circuit board. Note that tweezers may need to be used to help pull the tab out. 3.    Remove battery by carefully detaching the connect wire that’s connected to the circuit board. Note that tweezers may need to be used to help pull the tab out.
    • 3. Remove battery by carefully detaching the connect wire that’s connected to the circuit board. Note that tweezers may need to be used to help pull the tab out.
  5. 4.    The screen has 3 different sections, each held down by glue so necessary force is needed. First remove the acrylic backing that supports the screen and then the main part of the screen. The last thing to remove is the paper-thin cover. 4.    The screen has 3 different sections, each held down by glue so necessary force is needed. First remove the acrylic backing that supports the screen and then the main part of the screen. The last thing to remove is the paper-thin cover. 4.    The screen has 3 different sections, each held down by glue so necessary force is needed. First remove the acrylic backing that supports the screen and then the main part of the screen. The last thing to remove is the paper-thin cover.
    • 4. The screen has 3 different sections, each held down by glue so necessary force is needed. First remove the acrylic backing that supports the screen and then the main part of the screen. The last thing to remove is the paper-thin cover.
  6. 5.    Removing the touchpad is easy and simple as there are layered parts on top of each other, just simply pull them off. 5.    Removing the touchpad is easy and simple as there are layered parts on top of each other, just simply pull them off. 5.    Removing the touchpad is easy and simple as there are layered parts on top of each other, just simply pull them off.
    • 5. Removing the touchpad is easy and simple as there are layered parts on top of each other, just simply pull them off.
  7. 6.    Finally you should have the ipod dismantelled and you should be able to put the ipod back together.
    • 6. Finally you should have the ipod dismantelled and you should be able to put the ipod back together.
Craig Lawrence
Membro desde: 11-03-2010
444 Reputação
Autoria de 1 guia
when i put the rear cover back on, the charging station doesn't line up correctly and the charging station sticks out a bit. any advice?
krnchang - Responder
is the batter swollen
Derek King - Responder
Yes, happened to a Zune 80 I have
Crazyblocks Technologies -
Thank you for this - took the fear factor out of changing battery on my much loved Nano!
jimbradshaw - Responder
It’s extremely hard to connect LCD and Button cables. I screwed it up while reconnecting the cables. IF, you want to disassemble this machine by fun, don’t ever try it.
Sizun Cho - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 100
Duração total: 22,354
