Ir para o conteúdo principal
Este teardown está em andamento – Atualizar periodicamente para ver as últimas alterações!
O que você precisa
  1. iPhone dock Teardown, Getting started: passo 1, imagem 1 %32 iPhone dock Teardown, Getting started: passo 1, imagem 2 %32
    • Start by flipping the dock upside down.
  2. iPhone dock Teardown, Removing the back: passo 2, imagem 1 %32 iPhone dock Teardown, Removing the back: passo 2, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Jimmy
    $7.95
    Comprar
    • Take your Jimmy and push it in between the bottom cover and the body. Push down to lift the bottom cover.
  3. iPhone dock Teardown, Getting the back off: passo 3, imagem 1 %32 iPhone dock Teardown, Getting the back off: passo 3, imagem 2 %32
    • Carefully remove the clips on the side by pushing up with the Jimmy. If needed, use the plastic Opening Picks to keep the back piece from popping back into place.
    Note: make sure that you are lifting with your jimmy the deep-down metal part together with the upper plastic cover. Otherwise you’ll break it apart - it is connected with each other by the bellow described phillips screws.
    Filip - Responder
  4. iPhone dock Teardown, Looking at the dock: passo 4, imagem 1 %32
    • Remove the dock completely from the plastic frame.
  5. iPhone dock Teardown, Peeling back the black sticker: passo 5, imagem 1 %32 iPhone dock Teardown, Peeling back the black sticker: passo 5, imagem 2 %32 iPhone dock Teardown, Peeling back the black sticker: passo 5, imagem 3 %32
    • The silver adhesive is covering two Phillips screws at opposite ends of the dock. Peel back the adhesive on these areas and remove both screws.
  6. iPhone dock Teardown, Removing fore Phillips 000 screws: passo 6, imagem 1 %32
    • Remove the back plate once the screws are out.
    • Remove four Phillips #000 screws surrounding the lighting connection.
  7. iPhone dock Teardown, Removing the lighting adapter: passo 7, imagem 1 %32 iPhone dock Teardown, Removing the lighting adapter: passo 7, imagem 2 %32
    • A similar adhesive can be found covering the plug for the lightning adaptor. Peel the adhesive back and gently lift the cable to disconnect the adaptor.
Nathan
Membro desde: 09/21/17
386 Reputação
Autoria de 2 guias
Um comentário
is it possible to find the lighting connector, since I have one that fell and it got all twisted and damaged and it tore the connector
Uriel Ramos - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 15
Duração total: 2,089
