Ir para o conteúdo principal
O que você precisa
Vídeo de Apresentação
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua iPad Pro 12.9" 4th Gen, use o nosso manual de serviço.
    Considerações finais
    • The USB-C port is modular and can be independently replaced.
    • The lack of a physical home button eliminates a common failure point and may simplify repairs.
    • The battery is secured with both easier-to-remove stretch-release tabs and conventional, non-removable adhesive.
    • The LCD and front panel glass are fused together—simplifying the opening procedure, but increasing the cost of repair.
    • Gobs of adhesive hold most everything in place, making all repairs more difficult.
    Índice de reparabilidade
    3
    Reparabilidade 3 de 10
    (10 é o mais fácil de reparar)
Taylor Dixon
Membro desde: 06/26/18
67.033 Reputação
Autoria de 94 guias
8 comentários
Who manufactures the LiDAR hardware?
Shaun O'Flaherty - Responder
Looks like a ToF not real LiDAR. Apple marketing spin again
i.thanh -
https://tof-insights.com/time-of-flight-... Goes into details on pros and cons of a ToF versus LiDAR - and it appears there are many reasons why it makes sense to do a TOF LiDAR versus a full system when we are talking about a mobile device. Marketing spin, I hardly think so. It’s achieving the same functionality with many benefits on the device end.
Andrew C. A. -
When are you going to get a look at the IC’s in this?
Sean Davis - Responder
it actually is a lidar and not a time of flight camera
cool tech with mick - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 34
Últimos 30 dias: 189
Duração total: 52,255
