Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua iPad Mini 3 Wi-Fi, use o nosso manual de serviço.
  1. iPad Mini 3 Wi-Fi Teardown, iPad Mini 3 Wi-Fi Teardown: passo 1, imagem 1 %32
    • Pint-sized tech means pint-sized specs! Inside the iPad Mini 3, we expect to find:
    • 7.9-inch (diagonal) LED-backlit Multi-Touch display with IPS technology
    • A7 chip with 64‑bit architecture + M7 motion coprocessor
    • 5 MP iSight camera + 1.2 MP FaceTime HD camera
    • Wi‑Fi (802.11a/​b/​g/​n) with dual channel (2.4GHz and 5GHz) and MIMO support + Bluetooth 4.0
    • 23.8 Wh rechargeable lithium-polymer battery
    • Three-axis gyro + accelerometer + ambient light sensor
  2. iPad Mini 3 Wi-Fi Teardown: passo 2, imagem 1 %32 iPad Mini 3 Wi-Fi Teardown: passo 2, imagem 2 %32
    • If you were wondering how to tell the iPad Mini Retina Display (aka iPad Mini 2) apart from the iPad Mini 3, we've got you covered:
    • The iPad Mini 3 now supports Touch ID, to be used in conjunction with  Pay.
    • Gold. So much gold. Gold everywhere.
    • Continuing the trend set by the iPad Air 2, the iPad Mini 3 sports the model number A1599.
  3. iPad Mini 3 Wi-Fi Teardown: passo 3, imagem 1 %32 iPad Mini 3 Wi-Fi Teardown: passo 3, imagem 2 %32 iPad Mini 3 Wi-Fi Teardown: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    iOpener
    $19.99
    Comprar
    • The iOpener has revolutionized the way we open up iPads.
    • A little heat is just the thing to soften up the adhesive securing the iPad's display.
    • We place our iOpener around the perimeter of the iPad Mini 3 and begin using our opening picks to separate the front panel from the rear case.
    • After a bit of work and patience, we achieve our goal.
  4. iPad Mini 3 Wi-Fi Teardown: passo 4, imagem 1 %32 iPad Mini 3 Wi-Fi Teardown: passo 4, imagem 2 %32 iPad Mini 3 Wi-Fi Teardown: passo 4, imagem 3 %32
    • As is often the case with updates that don't really change anything, nothing has really changed yet.
    • Unlike in the new iPad Air 2, the front panel glass and LCD are still separate components, individually replaceable.
    • Take a look, it's in a book...
    • With the LCD out, we find our first and only change in construction: Some absolutely terrific home button cabling. Wow. That wasn't last-minute at all.
    • Is that hot glue?
  5. iPad Mini 3 Wi-Fi Teardown: passo 5, imagem 1 %32 iPad Mini 3 Wi-Fi Teardown: passo 5, imagem 2 %32 iPad Mini 3 Wi-Fi Teardown: passo 5, imagem 3 %32
    • Yes—that is hot glue, holding the home button bracket to the front panel. Good luck transferring that to your replacement glass. (Which you're going to have to do, to keep the Touch ID functionality after a cracked screen repair.)
    • Looks like the cable is a bit of a nightmare all by itself.
    • Apple's system for implementing Touch ID seems to require launching about a year before it's ready. Remember the Touch ID cable in the iPhone 5s? And the much-improved placement in the iPhone 6?
    • No surprises here: Touch ID in the Mini is powered by an NXP Semiconductors 8416A1 Touch ID Sensor.
  6. iPad Mini 3 Wi-Fi Teardown: passo 6, imagem 1 %32
    • Logic board! Let's just get to it, shall we? Anything new?
    • Apple A7 APL0698 SoC
    • Within the A7 package we find SK Hynix H9CKNNN8KTARKR 1 GB LPDDR3 DRAM
    • SK Hynix H2JTDG8UD1BMR 16 GB NAND Flash
    • Universal Scientific Industrial 339S0213 Wi-Fi Module
    • Apple 343S00004-A1
    • NXP Semiconductors 65V10 NFC Controller
    would seriously love a schematic for this. think mine has a blown resistor
    flow in - Responder
  7. iPad Mini 3 Wi-Fi Teardown: passo 7, imagem 1 %32
    • NXP Semiconductors LPC18A1 (Apple M7 Motion Co-Processor)
    • Apple (Cirrus Logic) 338S1213 Audio Codec
    • Apple 338S1199—likely a pair of audio amplifiers, similar to the Apple 338S1077 found in the previous iPad mini
    • Fairchild Semiconductor FDMC6676BZ and FDCM6683 MOSFETs
    • NXP 1610A1 Display Interface IC
    Why not mark Gyro,Compass and Accelerometer between yellow and orange marked ic's?
    Filip Pusca - Responder
    nice to see the home button is removable on this version.
    Nick - Responder
    Yes,but now Apple blocks non genuine Touch ID sensors,thank goodness there's nothing wrong with my iPad mini 3,in fact I've had it in an OtterBox case for a year and a half and it looks absolutely perfect
    Daniel Gartin -
  8. iPad Mini 3 Wi-Fi Teardown: passo 8, imagem 1 %32 iPad Mini 3 Wi-Fi Teardown: passo 8, imagem 2 %32
    • iPad Mini 3 Repairability: 2 out of 10 (10 is easiest to repair).
    • The LCD and glass are not fused together and can be replaced independently.
    • The battery is not soldered to the logic board or other components.
    • Copious amounts of adhesive hold many components in place—front glass, battery, front camera, back camera, ribbon cables—making repair extremely difficult.
    • The Lightning connector is soldered to the logic board, so don't bend its pins.
    • Removing the home button is now a much more difficult job. If you want to keep Touch ID functionality after a screen replacement, you'll have to transfer the home button to the new front panel.
Geoff Wacker
Membro desde: 09/30/13
89.931 Reputação
Autoria de 89 guias
10 comentários
Is the digitizer the same as the iPad Mini 1/2?
npham54 - Responder
You can test the connectors are same.
Filip Pusca -
I've looked better at the circuit on BRD and can tell you that iPad Mini 3 have different circuit for touch screen connector, but iPad Mini 1 and iPad Mini 2 have same circuit.
Filip Pusca -
What is really important, to show there the glue is on the iPad, I don't see that the glue is all around the Display, only in the edges under the Home button an of cause over the camera, please show this better ! Thank You for sharing your DIY :-)
gorednet - Responder
Thank god there is nothing wrong with mine,in fact it still looks brand new,but i have these guides in case something happens
Daniel Gartin - Responder
Thank goodness there is nothing wrong eith my iPad mini 3,in fact it still looks brand new
are you guys crazy not even my dad can do that am just 13 years old
Tabo Mbinji - Responder
I changed the screen and the connector that is on the iPad board, some of the pieces came off. It connects but because all of the components of the connector are not there it doesn't work. Is there a way to replace this on the iPad itself?
Nicole Fiore - Responder
My charging port ain’t working. Can i replace it with that of an ipad 4?
Abdulmalik Ahmad - Responder
Thanks for the guide, I found a broken one on eBay for bout 26 bucks, thinking of restoring it for some profit. This guide shows it’s not the most hardest thing, plus I just need to replace the digitizer, maybe also the battery. Thanks again! :)
fakevillagernews SAAMM13 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 44
Duração total: 80,882
