Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua iControl Networks Piper, use o nosso manual de serviço.
  1. iControl Networks Piper Teardown, Cracking Open The Case: passo 1, imagem 1 %32
    • Piper is held together with four "security Philips" screws located in the battery case. Each screw has a post in the middle, meant to foil use of a standard screwdriver. However....
    • If you don't have the right bit, just use a large #2 philips head screwdriver: the bit won't go deep enough to get tangled up in the security feature.
    • Once the screws are out use a plastic spludger to pry open four plastic clips holding the shell together.
  2. iControl Networks Piper Teardown, What's Inside: passo 2, imagem 1 %32 iControl Networks Piper Teardown, What's Inside: passo 2, imagem 2 %32 iControl Networks Piper Teardown, What's Inside: passo 2, imagem 3 %32
    • Piper is dominated by a large speaker, and a Mallory PS-953Q security horn. It's loud. The CPU is a Texas Instruments TMS320DM365 media processor with a ZW0301 based Z-Wave module.
    • Piper uses two tiny antennas, one for Z-Wave one for WiFi.
    • That's it... a pretty simple layout.
Bryce Nesbitt
Membro desde: 11/30/14
1.206 Reputação
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Ao todo: 2,339
