Pular para o conteúdo principal
Ajuda
Editando passo 21 —
Tipo de Passo:
Arraste para reorganizar
As is the case with most tablets, the iPad 3 is really just a giant battery.
Some help from our spudger allows us to remove the battery from the device for further inspection.
While the iPad 2 housed a formidable 25 watt-hour Li-ion battery, the iPad 3 has upped the ante to the tune of 42.5 watt-hours.
Its 3.7 volts and estimated 10 hours of use (9 with cellular data network) are comparable to that of the iPad 2, but we assume the extra 17.5 watt-hours are put to good use powering the extra RAM and greatly improved GPU.
The battery has three cells, each approximately 12.5 cm x 6.5 cm x 4 mm. The iPad 2's battery cells were 10.8 cm x 6.3 cm x 2.7mm.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
