Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Ajuda
Editando passo 7 —
Tipo de Passo:
Arraste para reorganizar
Careful! If you don't remove the feet and the screws underneath before you try to pull off the front panel, the tab can split!
Once all screws are removed, you should be able to pull off the front drive panel.
The wire connecting the front panel (green squares in the third image) can be pulled out gently by hand or with the help of a spudger.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
