Pular para o conteúdo principal
Ajuda
Editando passo 18 —
Tipo de Passo:
There have been early rumors of durability problems with the rail mechanism for the Joy-Con units, so we pause for a closer look.
The rail itself, on the edge of the Switch Console, is metal and seems like it should hold up pretty well.
Its mate on the Joy-Con side is plastic, which is probably exactly what you want—any failure will most likely be in the detachable controller, which should be cheaper to repair or replace if necessary.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
