Ajuda
Editando passo 1 —
Tipo de Passo:
Arraste para reorganizar
Flip the Sony Walkman so that its rear side faces you.
Use a screwdriver to remove the two screws from the surface of the Walkman.
Both the screws are highlighted in red in the image.
Press the battery plate slightly with your thumb and slide it downwards. This will open the battery compartment.
The battery compartment is highlighted in blue in the image.
Remove the batteries from the Walkman.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
