Ir para o conteúdo principal
Ajuda
Editando passo 20 —
Tipo de Passo:
Arraste para reorganizar
The display assembly is attached to the case with 19 small screws:
Four (relatively) large Torx which screw into the hinges.
Thirteen #00 Phillips which hold down the clutch cover.
And two #00 Phillips which screw into cable ground loops.
Apple made no compromises on the Air's display. Amazingly, the entire display assembly weighs only 465 g (slightly more than a pound), 34 percent less than the functionally-equivalent display assembly on the MacBook.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
