Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Ajuda
Editando passo 3 —
Tipo de Passo:
Arraste para reorganizar
The 1000mAh 11.1V lithium polymer battery is attached via a connector, making it delightfully easy to remove.
The second connector is a balance charge connector, which ensures that each of the three battery cells is charging equally, thus optimizing capacity and prolonging battery life.
The battery contains a protection circuit module, which prevents it from discharging too rapidly, over charging, or short circuiting.
Parrot claims the battery will only last about 12 minutes after a full charge, which takes around 90 minutes. Taking your AR.Drone out to the park with only one battery won't get you much play time, unfortunately.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
