Pular para o conteúdo principal
Ajuda
Editando passo 2 —
Tipo de Passo:
Arraste para reorganizar
Here is a close-up of the ports on the front. You usually hook this up inside your company firewall.
I did not see the console port documented. It uses a RJ-45 connector (more properly called an 8P8C connector.) I don't know what the pin-out on it is, but as you'll see, its connected to the serial port.
In background, you can see the huge fan which blows across the motherboard. I think this is the one making most of the noise.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
