Ir para o conteúdo principal
Fix Your Stuff
Right to Repair
Parts & Tools
Help
Editando passo 5 —
Tipo de Passo:
Arraste para reorganizar
now remove the upper blue plastic from the iron itself.
click the wires loose. ( you can click it loose at the metal part of the wire,there is a little metal clip you have to push and then pull the wire out.)
if you put it togheter again , notice that the steam button is in his place.
note: again, see where the wires run at.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
