Ir para o conteúdo principal
Ajuda
Editando passo 21 —
Tipo de Passo:
Arraste para reorganizar
OnePlus One Repairability Score: 5 out of 10 (10 is easiest to repair).
No proprietary screws and only one screw head type decreases cost of tools for repairs.
Fairly modular components will allow for less expensive replacement parts.
Slight adhesive used on the battery and several cables.
With its connector trapped under a plastic panel and several screws, the battery is more of a chore to replace than necessary.
The LCD and digitizer glass are fused together and must be replaced as a single part, and they require heat to remove from the midframe.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
