Ir para o conteúdo principal
Ajuda
Editando passo 86 —
Tipo de Passo:
Arraste para reorganizar
The only thing now preventing the two frames from being separated is this gear.
It is fixed to the shaft with a taper pin.
A taper pin is a pin that tapers from a wide end to a narrow end used to affix parts onto a shaft. The machinist would put the gear on the shaft, drill a hole, then taper the hole by using a tapering reamer. Then the machinist would put the taper pin in, give it a few gentle whacks with a hammer, and grind off any end sticking out too much.
Taper pins were better than set screws because a taper pin leaves no possibility for the parts to rotate.
They're also a pain to remove after 90 years.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
