Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Ajuda
Editando passo 68 —
Tipo de Passo:
Arraste para reorganizar
On the left rear, remove these three screws, #8-36, 5/16".
The screw on the right is difficult to get to. Use a long thin screwdriver to loosen the screw a tiny bit, then a smaller screwdriver to remove the screw.
The screw on the right holds down two parts.
The screw on the left has a hook for a spring which runs along the length of the machine. You will likely be able to remove a short segment of the larger surrounding spring. Hook the end of the interior spring around the bushing after removing the short outer spring segment.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
