Pular para o conteúdo principal
Ajuda
Editando passo 9 —
Tipo de Passo:
Arraste para reorganizar
All the circuit boards are attatched with wiring which makes it hard to remove all the components without damaged to the phone. To remove properly you need to remove to solder holding the wiring to other componets, or you can just cut the wires.
The boards are held down with small screws, simply remove the scres to access the underside of the circuit boards.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
