Ir para o conteúdo principal
Fix Your Stuff
Right to Repair
Parts & Tools
Help
Editando passo 11 —
Tipo de Passo:
Arraste para reorganizar
Get your groove on with the single 2W mono speaker mounted flush in the plastic chassis.
After removing the four Phillips screws securing the speaker to the chassis, use a sharp blade to carefully separate the speaker cables from the adhesive applied near the speaker opening.
The speaker wires are glued down to avoid any rattling noises from ruining your air guitar solo.
The speaker has a 7/8" concave aluminum diaphragm held to the frame with a foam rubber surround.
The white panel on the chassis is fitted with a conical port presumably to eliminate resonance.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
