Ir para o conteúdo principal
Fix Your Stuff
Right to Repair
Parts & Tools
Help
Editando passo 5 —
Tipo de Passo:
Arraste para reorganizar
The volume knob is simply pressed onto the splined volume control shaft.
Use a plastic opening tool to pry evenly around the edge of the volume knob until you can remove it from the chumby.
Volume control commands are sent via a rotary encoder that translates angular degrees of rotation into binary code recognized by the board.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
