Ir para o conteúdo principal
Fix Your Stuff
Right to Repair
Parts & Tools
Help
Editando passo 3 —
Tipo de Passo:
Arraste para reorganizar
Slide the lower case away from the front of the chumby, then tilt it away from the logic board to reveal the battery connector. Taking as many precautions as possible, we decided to disconnect the battery connector from the logic board assembly.
Use a plastic opening tool to dislodge the plug of hot glue holding the FM antenna wire in the lower case. At this point you can de-route the FM antenna wire and remove the lower case from the chumby.
chumby industries, inc. recommends using only a Fujifilm NP-120 battery.
The NP-120 is a rechargeable Lithium-Ion camera battery. The chumby is equipped with circuitry to charge the battery when it is plugged into AC power.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
