Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Ajuda
Editando passo 2 —
Tipo de Passo:
Arraste para reorganizar
First use a thin metal spudger to remove the four self-adhesive plastic dots covering the screw holes.
Remove the four Phillips screws holding the cases together. You'll need a thin-shafted screwdriver to remove them.
Ventilation holes abound in the top and rear outer cases. Such a Swiss cheese case design allows the chumby to cool off without the need for a fan.
There are no screws in the bottom case; it is held in place when the cases are fastened together.
Pull the rear case away from the chumby to reveal the spiffy internals.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
