Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Ajuda
Editando passo 13 —
Tipo de Passo:
Arraste para reorganizar
The Motorola Razr earns a 1 out of 10 on our repairability scale (10 is easiest to repair):
The only driver you'll need is a standard T3 Torx.
The delicate primary display is replaceable, if you're determined.
Every repair starts (and ends) with stubborn, glued-on outer covers.
Replacing the battery—or rather, batteries—requires near-total disassembly.
The charging port is soldered directly to the main board.
Complex construction and multiple flex cable booby traps makes for tricky repair work.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
