Ir para o conteúdo principal
Ajuda
Editando passo 3 —
Tipo de Passo:
Arraste para reorganizar
Detach the vibration motor cable from the PCB.
DO NOT use the cable to remove from the PCB. You may damage the motor, connector, or PCB by pulling on the cable.
After detaching the vibration motor cable from the PCB, remove the vibration motor.
Utilize the same technique for the other vibration motor on the opposite side.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
