Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Ajuda
Editando passo 16 —
Tipo de Passo:
Arraste para reorganizar
Now there will be a tiny circuit switch upright after removing the fan channel.
Remove simply by lifting out out placement niche
This, I found is a neat little cutoff switch. Being that the little black switch is located at the underside of the unit in the Lamp assembly door. If the Switch is not depressed that means the door is not closed and power will not be applied to the lamp-Safety Feature
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
