Ir para o conteúdo principal
Ajuda
Editando passo 14 —
Tipo de Passo:
Arraste para reorganizar
Next we turn our attention to Apple’s much-discussed Liquid Retina display.
The XR’s LCD is 0.3” larger across than the XS’s AMOLED, but it’s also thicker and heavier—as is expected from an LCD.
The need for a backlight means an LCD display assembly will always necessitate a slightly larger form factor than an equivalent AMOLED assembly.
As far as we can tell, this thicker display assembly is what has pushed the Lightning connector off-axis.
Getting back into the case, we dig out the wireless charging coil for a closer look.
We’ve struck copper! Copper’s lower resistance (compared to FPC in the X) should mean faster charging with less heat.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
