Pular para o conteúdo principal
Ajuda
Editando passo 3 —
Tipo de Passo:
Arraste para reorganizar
Lift dipping pan from the plastic casing.
Dipping pan connects to plastic casing with nondetachable wiring.
The two wires connected to the black connector transfer the AC power from the base to the heating coil underneath the pan surface.
White sleeves surround the wires, protecting them from heat damage.
The black connector also holds a grounding strip not connected to a wire.
Used crepe makers will probably look as dirty as this. Unless you are the cleanest person to ever exist.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
