Pular para o conteúdo principal
Ferramentas utilizadas neste teardown
Introdução
This guide will show you the steps to take the back off the ZTE T81 and remove the mainboard and the screen.
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua ZTE T81, use o nosso manual de serviço.
  1. Remove the back cover, SIM card, battery and SD card.
    • Remove the back cover, SIM card, battery and SD card.
  2. Remove the 9 screws under the back cover. The top left screw is covered by a white "warranty void" sticker. Remove the 9 screws under the back cover. The top left screw is covered by a white "warranty void" sticker.
    • Remove the 9 screws under the back cover. The top left screw is covered by a white "warranty void" sticker.
  3. Separate the frame from the mainboard Pry apart the frame with the battery holder and camera housing from the mainboard of the phone.
    • Separate the frame from the mainboard
    • Pry apart the frame with the battery holder and camera housing from the mainboard of the phone.
  4. PC Laptop Batteries
    An easy fix for a big power boost.
    Comprar agora
    PC Laptop Batteries
    Comprar agora
  5. Remove the digitizer cable and separate the digitizer/front glass from the rest of the phone. Remove the digitizer cable and separate the digitizer/front glass from the rest of the phone.
    • Remove the digitizer cable and separate the digitizer/front glass from the rest of the phone.
  6. Unplug the LCD screen from the mainboard and carefully peel the display off the mainboard. It is only stuck on. Unplug the LCD screen from the mainboard and carefully peel the display off the mainboard. It is only stuck on. Unplug the LCD screen from the mainboard and carefully peel the display off the mainboard. It is only stuck on.
    • Unplug the LCD screen from the mainboard and carefully peel the display off the mainboard. It is only stuck on.
  7. Insert wisdom here. Insert wisdom here.
    • Insert wisdom here.
domenicofavotto1
Membro desde: 26-08-2015
101 reputação
Autoria de 1 guia
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Todo: 1,163
