Ir para o conteúdo principal
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Xbox 360 Wireless Controller, use o nosso manual de serviço.
  1. Place the controller face down on your working surface to allow access to rear screws. Take the battery compartment out. Use a TR9 bit and screwdriver to remove all 7 screws.
    • Place the controller face down on your working surface to allow access to rear screws.
    • Take the battery compartment out.
    • Use a TR9 bit and screwdriver to remove all 7 screws.
  2. Remove the rear half of the controller by pulling perpendicular to the front half. The battery terminals have specific grooves that they slide in and out of.
    • Remove the rear half of the controller by pulling perpendicular to the front half.
    • The battery terminals have specific grooves that they slide in and out of.
    • If the two halves do not easily separate, you can slide a spudger along the seam and/or slightly depress the left/right triggers.
  3. Detach the vibration motor cable from the PCB. DO NOT use the cable to remove from the PCB. You may damage the motor, connector, or PCB by pulling on the cable.
    • Detach the vibration motor cable from the PCB.
    • DO NOT use the cable to remove from the PCB. You may damage the motor, connector, or PCB by pulling on the cable.
    • After detaching the vibration motor cable from the PCB, remove the vibration motor.
    • Utilize the same technique for the other vibration motor on the opposite side.
  4. Make sure the front half of the controller is facing towards you. The PCB should simply lift out with little to no force when being held by the areas highlighted.
    • Make sure the front half of the controller is facing towards you.
    • The PCB should simply lift out with little to no force when being held by the areas highlighted.
    • If the PCB doesn't freely lift out, apply light consistent leverage under the highlighted area.
    • Be cognizant of the components on the opposing side of the PCB.
    How do i remove the little springs for the battery area and put new ones in
    Final - Responder
  5. Full IC Identification:
    • Full IC Identification:
    • You may need to enlarge it to view the text.
  6. Gently peel off the conductive rubber pads to expose the backsides of the buttons Remove the A, B, X, Y, Back, Start and Guide buttons. The Guide button sleeve may also be removed. You can now remove the bumper assembly at the top.
    • Gently peel off the conductive rubber pads to expose the backsides of the buttons
    • Remove the A, B, X, Y, Back, Start and Guide buttons. The Guide button sleeve may also be removed.
    • You can now remove the bumper assembly at the top.
  7. Remove the last two screws in the D-pad with a #0 Phillips screwdriver.
    • Remove the last two screws in the D-pad with a #0 Phillips screwdriver.
    • Use a pair of tweezers to squeeze the clips together and remove the D-pad.
  8. And here is the final result: a completely disassembled Xbox 360 Wireless Controller.
    • And here is the final result: a completely disassembled Xbox 360 Wireless Controller.
Mart-Jan
Membro desde: 26/05/2019
300 Reputação
Autoria de 1 guia
Um comentário
Excelente trabajos
RIGO NOLASCO - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 13
Últimos 7 dias: 168
Últimos 30 dias: 852
Duração total: 12,970
