Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Xbox 360 Wireless Controller, use o nosso manual de serviço.
  1. Xbox 360 Wireless Controller Teardown, Removing the first screws: passo 1, imagem 1 %32 Xbox 360 Wireless Controller Teardown, Removing the first screws: passo 1, imagem 2 %32 Xbox 360 Wireless Controller Teardown, Removing the first screws: passo 1, imagem 3 %32
    • Place the controller face down on your working surface to allow access to rear screws.
    • Take the battery compartment out.
    • Use a TR9 bit and screwdriver to remove all 7 screws.
  2. Xbox 360 Wireless Controller Teardown, Removing the back: passo 2, imagem 1 %32 Xbox 360 Wireless Controller Teardown, Removing the back: passo 2, imagem 2 %32
    • Remove the rear half of the controller by pulling perpendicular to the front half.
    • The battery terminals have specific grooves that they slide in and out of.
    • If the two halves do not easily separate, you can slide a spudger along the seam and/or slightly depress the left/right triggers.
  3. Xbox 360 Wireless Controller Teardown, Removing the vibration motors: passo 3, imagem 1 %32 Xbox 360 Wireless Controller Teardown, Removing the vibration motors: passo 3, imagem 2 %32
    • Detach the vibration motor cable from the PCB.
    • DO NOT use the cable to remove from the PCB. You may damage the motor, connector, or PCB by pulling on the cable.
    • After detaching the vibration motor cable from the PCB, remove the vibration motor.
    • Utilize the same technique for the other vibration motor on the opposite side.
  4. Xbox 360 Wireless Controller Teardown, Removing the PCB: passo 4, imagem 1 %32 Xbox 360 Wireless Controller Teardown, Removing the PCB: passo 4, imagem 2 %32
    • Make sure the front half of the controller is facing towards you.
    • The PCB should simply lift out with little to no force when being held by the areas highlighted.
    • If the PCB doesn't freely lift out, apply light consistent leverage under the highlighted area.
    • Be cognizant of the components on the opposing side of the PCB.
  5. Xbox 360 Wireless Controller Teardown: passo 5, imagem 1 %32
    • Full IC Identification:
    • You may need to enlarge it to view the text.
  6. Xbox 360 Wireless Controller Teardown, Removing the buttons and the bumper: passo 6, imagem 1 %32 Xbox 360 Wireless Controller Teardown, Removing the buttons and the bumper: passo 6, imagem 2 %32 Xbox 360 Wireless Controller Teardown, Removing the buttons and the bumper: passo 6, imagem 3 %32
    • Gently peel off the conductive rubber pads to expose the backsides of the buttons
    • Remove the A, B, X, Y, Back, Start and Guide buttons. The Guide button sleeve may also be removed.
    • You can now remove the bumper assembly at the top.
  7. Xbox 360 Wireless Controller Teardown, Removing the D-Pad: passo 7, imagem 1 %32
    • Remove the last two screws in the D-pad with a #0 Phillips screwdriver.
    • Use a pair of tweezers to squeeze the clips together and remove the D-pad.
  8. Xbox 360 Wireless Controller Teardown, End result: passo 8, imagem 1 %32
    • And here is the final result: a completely disassembled Xbox 360 Wireless Controller.
Mart-Jan
Membro desde: 05/26/19
305 Reputação
Autoria de 1 guia
3 comentários
Very clear, helped me clean my controller. Thank you :)
Taydolf Swiftler - Responder
Hello. I just did clean one of mine that i did bye 2011. The Rumble on left end right are the opposit to this guide.
I did never disconnect them from the pcb. So ma bey its another revision or the left and right is missing.
From the back.
Small left , big right.
https://imgur.com/a/DxXdUNB
Michael Orban - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 27
Últimos 7 dias: 200
Últimos 30 dias: 1,026
Duração total: 39,229
