Ferramentas utilizadas neste teardown
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Xbox 360 Wireless Controller, use o nosso manual de serviço.
  1. Remove 7 screws using the T3 Toolbit located on the back of the controller.
    • Remove 7 screws using the T3 Toolbit located on the back of the controller.
  2. Then take off and replace the analog sticks if they arent functioning correctly. Then take off and replace the analog sticks if they arent functioning correctly. Then take off and replace the analog sticks if they arent functioning correctly.
    • Then take off and replace the analog sticks if they arent functioning correctly.
  3. Kits de reparo de android
    A new screen or battery is one kit away.
    Comprar agora
    Comprar agora
  4. Remove two screws from the D-Pad using a Phillips #0 Screwdriver, After doing so, you will see two latches underneath the screws that you just removed and you have to press the two latches at the same time to completely remove the D-Pad.
    • Remove two screws from the D-Pad using a Phillips #0 Screwdriver, After doing so, you will see two latches underneath the screws that you just removed and you have to press the two latches at the same time to completely remove the D-Pad.
  5. If you followed these directions successfully this is what the final result  should look like. If you followed these directions successfully this is what the final result  should look like.
    • If you followed these directions successfully this is what the final result should look like.
RareWarrior123
Membro desde: 26-04-2019
119 Reputation
Autoria de 1 guia
0 Comments
Past 24 Hours: 8
Past 7 Days: 36
Past 30 Days: 169
All Time: 973
