O que você precisa
Remove the blades by pulling away from the enclosure
Remove the speed control by pulling away from the enclosure
Remove the 4 screws coupling the orange plastic enclosure and black plastic guard
Remove the screw coupling the top half of the enclosure
Remove the screw coupling the bottom of the enclosure, near the power cable
Remove the screw beneath the rubber inserts holding the stand
Separate the two halves of the enclosure, leaving the power cable, switch, motor and guard
Remove the 2 screws attaching the guard to the motor
Remove the 2 screws holding the switch in the mount connected to the motor
2Comentários do guia
Mine was making noise and difficult to get the nose cone pulled off. I used two coins in the crack on opposing sides and twisted them.
it won't keep it`s position ,folds and flaps out ,if i could tighten the arm
