Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Uniden EXP 371, use o nosso manual de serviço.
  1. Uniden EXP 371 Teardown, Uniden EXP 371 Teardown: passo 1, imagem 1 %32
    • Uniden EXP371 900 MHz Cordless Phone.
    • 900 MHz Extended Range with One Touch RocketDial/Find Handset Locator and is Desk or Wall Mountable.
  2. Uniden EXP 371 Teardown: passo 2, imagem 1 %32 Uniden EXP 371 Teardown: passo 2, imagem 2 %32
    • Remove the battery by first pressing down on the rear of the cover and pushing the cover towards the bottom of the phone.
    • Next remove the battery by pulling on the connector.
  3. Uniden EXP 371 Teardown: passo 3, imagem 1 %32 Uniden EXP 371 Teardown: passo 3, imagem 2 %32
    • Next remove the two screws at the bottom of the phone with a PH1 philips screwdriver.
    • Now remove the top portion of the case from the bottom. This may be difficult to do with your bare hands. The use of a plastic opening tool may come in handy.
  4. Uniden EXP 371 Teardown: passo 4, imagem 1 %32 Uniden EXP 371 Teardown: passo 4, imagem 2 %32 Uniden EXP 371 Teardown: passo 4, imagem 3 %32
    • Your next step is to remove the five screws holding down the motherboard. Use the PH1 philips screwdriver.
    • Once you have removed the five screws you may lift the motherboard off of the front case.
    • At this point you may also remove the dial pad. It simply lifts off.
    • You may also remove the speaker if needed by unscrewing the two screws using the PH1 philips screwdriver.
    • The whole phone is now disassembled at this point.
Tim Reimer
Membro desde: 06/19/10
165 Reputação
Autoria de 3 guias
Um comentário
this guide is poorly written, please delete or improve it.
Walker Quine - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Duração total: 4,582
