O que você precisa
Okay, don't freak out, but there are a BUNCH of clips and connectors to undo at this point, just keep calm and know where your towel is and all will be well.
Disconnect, using a spudger or fingernail, the following connectors:
USB header
Speakers
Power/media buttons
VGA connector and screw
Fan power
Modem connector (lift up tape)
Peel back the metallic tape from the fan
Lift the fan up and away from the vent
Tough part: Lift the motherboard at the rop right corner, find this cable underneath and gently wiggle it out.
Lift the board out, pivot it slightly to allow the audio connectors to come free, then simply lift.
5Comentários do guia
are you selling these parts? i desperately need a new screen for mine. Or do you know where I can find the screen replacement part??
you can email me at bleadinluv@gmail.com thank you bunches
erica
Is there a separate sound module? My A215 works great except for the sound which is nothing but crackle/static even with sound turned to very low. Same thing using headphones so the speakers themselves seem to be ok.
