O que você precisa
Starting functionality of toaster: toasts bread for a variable time depending on the knob setting when turned on.
Removing the bottom four screws allows the metal casing to open.
Unlatch bottom crumb collector by removing the metal tab and wires connecting it to the base of the metal structure. This reveals a way to clean the toaster in the future.
These covers were attached by the four screws at the bottom. To remove them, simply pull up and shimmy them out of their slots. However, the front cover still has electrical attachments.
The cord immobilizer is a small black plastic piece held in by screws.
This step requires a bit of muscle. The plastic lever is very well attached to the depressor lever. Then the front plastic cover can further be removed from the metal frame.
The circuit board is welded to the heated filaments. In order to further open up the toaster frame, this step is necessary.
The spring shown makes the lever bounce back up after the toast is done. The latches hold the toast in place when the lever is down.
