This guide is a step-by-step teardown of a Toaster Made by Design model KT-3215. The purpose of the guide is to provide a look into the internals of the toaster. This teardown is not intended to be followed for repair.
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Toaster, use o nosso manual de serviço.
Use your index finger and middle finger to grip the loading lever, then pull towards your body to remove the lever. A fair amount of force may be required.
Use a Phillips #2 x 4in. screwdriver to remove the four 0.25 in. Phillips head screws. These screws are securing the control board for the buttons and timer knob.
Use a pair of mini long-nose pliers to bend the metal lips located on the back of the toaster. The metal lips should be facing towards you after you have bent them.
Remove the waveguide cover (rectangular tan cover) on the back of the toaster.
Use a Phillips 2 x 4in. screwdriver to remove the two 0.25 in. Phillips head screws. These screws secure the back of the internal housing of the toaster.
Use a Phillips 2 x 4in. screwdriver to remove the two 0.25 in. Phillips head screws. These screws secure the front of the internal housing of the toaster.
