Introdução
Vorwerk served up its pioneer and flagship multifunctional kitchen machine with 2014's Thermomix TM5. The purchase price of over $1,100 isn’t too digestible for everyone's wallet; however, the device is supposed to conjure up some delicious dishes. Loved by some, despised by others, the Thermomix should not be left out when discussing cooking gadgets.
We wondered what the machine's ingredients were—so we competently dismantled and deboned it in order to find out.
To make sure that you always get the freshest teardowns served hot, you can drop by our Facebook page, have a look at our Instagram account and follow us on Twitter.
O que você precisa
This machine is capable of stirring, mixing, kneading, crushing, weighing, heating, cooking, and steaming.
However, what we're interested in is its inner life, which is why we make our own soup:
As a basis for our teardown we take...
... a Thermomix TM5 and separate the mixing bowl (including the cover) from the device.
Then we detach the recipe chip from the base unit.
Now we remove the program selector and motor shaft ring using the opening tool.
Once the program selector is removed, we remove the white holder so that the selector slides towards inside. In order to do that we turn it as indicated while we push backwards the clips highlighted in blue.
Now we first remove the three screws on the bottom side.
Then the six housing screws.
At last we remove the screw on the back side and then we can carefully open the housing with the opening tool.
Each time the mixing bowl cover is locked, a whole choreography of mechanics is triggered:
The first sensor (component of the 5-pin plug near the crankshaft) determines whether the mixing bowl is inserted at all.
Then the motor mechanically turns both arms and locks the mixing bowl cover.
Three more sensors check whether the cover is fixed and the handles are completely closed.
The next item on the menu is the control panel, which is used for most inputs.
The 4.3" (640×480 pixels) LCD TFT touch panel is inserted by simple plastic clips that can easily be detached by hand.
The board is served with two Torx screws on a ribbon cable connector. Here's what we find on it:
To get to the Thermomix fillet piece, we remove the selector knob encoder, the motor cover, and the 5-pin connector.
And out comes the juicy 500 Watt reluctance motor. It stirs at 40-500 rpm and mixes up to 10,700 rpm in turbo mode.
The accompaniment board features an NXP HEF4093B quad NAND gate with two inputs as Schmitt trigger for the engine control.
The Thermomix is fed with knowledge via the lateral interface with so-called recipe chips.
The interface with the 4 pins strongly smells of a standard USB connection. This connection is also used to make the Thermomix WLAN-enabled via Cook-Key®.
Four LEDs take over the lighting at the front. They sit in pairs on an exchangeable mini circuit board.
On the way to the core of the Thermomix, we pass a suspicious, almost empty cable box. That surely has something to do with some kind of DIN standard.
But we won’t let ourselves get distracted by such deco fruits. We take out the brain, which seems to only be of interest on one side— the backside just features a conductor salad:
To get the remaining cable giblets out, we once again take advantage of the flexible shaft extension for our precision bit holder.
We bravely grip everything and get it all out at once:
5-pin connector for the mixing bowl
LED light elements
5W speaker
3 rubber feet with load cells for the balance function
The Thermomix is dismantled into its components. We have tasted the TM5, and here's our conclusion:
We found no
hair in the soupproprietary screws; only Torx screws were used. -
The components are all individually exchangeable, even up to the LED boards.
Housing, display, motherboard, and a few smaller parts are mostly attached via easily accessible clip connections.
Some of the cable connections are somewhat tight and therefore difficult to access. This increases the risk of damage to the cables and connectors.
Um agradecimento especial a esses tradutores:
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
53 comentários
Malheureusement je ne connais pas la réponse, mais si vous postez la question dans notre Forum de réponses la chance d’obtenir une réponse de la part d’un autre membre de la communauté est beaucoup plus grande ;-)
Dommage que les pièces détachées ne soit pas disponible en tout cas pas à ma connaissance.
Les pièces ne sont pas disponibles dans notre boutique, mais vous êtes le bienvenu de poster cette question dans le Forum de réponses, peut-être que quelqu’un peut vous indiquer une bonne source.
