Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Texas Instruments TI-82, use o nosso manual de serviço.
  1. Texas Instruments TI-82 Teardown, Texas Instruments TI-82 Teardown: passo 1, imagem 1 %32
    • The calculator comes with a matching protective shield which slides down over the front; when the calculator is in use, you can slide it over the back. This is a nice touch, as it makes the cover much more difficult to lose.
  2. Texas Instruments TI-82 Teardown: passo 2, imagem 1 %32 Texas Instruments TI-82 Teardown: passo 2, imagem 2 %32 Texas Instruments TI-82 Teardown: passo 2, imagem 3 %32
    • Flip the device over to access the battery cover.
    • Using a spudger, pry the release tab down and then pull the battery door up and off the calculator.
    • Remove:
    • 2 7.2mm Phillips #0 screws
    • 1 15.3mm Phillips #0 screw, and a battery retaining clip.
    • The CR1616 coin cell battery preserves settings and programs in memory while the main batteries are being changed.
  3. Texas Instruments TI-82 Teardown: passo 3, imagem 1 %32
    • Insert a spudger into the seam between the two halves of the case, and pry it apart.
    • Watch out for corrosion in older calculators around the battery terminals -- this is why you should never leave batteries in electronics for extended periods of time.
  4. Texas Instruments TI-82 Teardown: passo 4, imagem 1 %32
    • Opening the two halves of the calculator reveals a foil shield over the rest of the electronics.
    • Remove four Phillips screws to access the electronics underneath, then pull the shield away.
  5. Texas Instruments TI-82 Teardown: passo 5, imagem 1 %32
    • ... And, here's the guts of the thing.
    • SRM20255LLM10 / F4ZM1938 (32Kbyte SRAM)
    • LH531GP4 (Mask ROM)
    • T 84C00AM-8 (Z80 CPU)
    • Toshiba / TC14L010AF / 1273 9506EAI (ASIC)
  6. Texas Instruments TI-82 Teardown: passo 6, imagem 1 %32 Texas Instruments TI-82 Teardown: passo 6, imagem 2 %32
    • Remove the remaining Phillips screws.
    • The screen and main board will lift out, leaving the membrane keypad in the front case.
bushing
Membro desde: 04/23/10
10.247 Reputação
Autoria de 13 guias
Um comentário
Minor correction, the RAM part is SRM20256LLM10, a CMOS 256 kilobit (32x8) 100ns static RAM in 28 pin SOP form factor.
Nick M - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 17
Últimos 30 dias: 90
Duração total: 20,580
