Introdução
A look inside the Technics EAH-AZ70 (Japan) / EAH-AZ70W (Outside Japan) Bluetooth Headphones
O que você precisa
Features:
Highest Level of Dual Hybrid Noise Cancelling. Multiple MEMS microphones
Graphene coated PEEK diaphragm speaker for smooth, clean, and elegant sound
Stable Connection in crowed areas
Excellent Quality Call Sound
Approximately 6.5 hours of playback, and up to 20 Hours of use with charger
Bluetooth® 5.0
Capacitive touch sensor control
Since the Technics Headphone enclosure is glued together, the only way in was to cut into the headphone.
This is a destructive teardown
A Razsor knife was use to cut into the Technics headphone along the seam in the headphone. Then a Jimmy Tool was used to open up the headphone. Tweezers and a Pick Tool were used to removed the electronics from the enclosure
Once opened, we get our first look at the inside of the headphone
Double sided foam tape was used to hold the main the PCB to the Battery and to the Touch Sensor / Antenna PCB. This foam tape had to be cut free. Then Denatured Alcohol was used to remove the foam tape glue from the PCBs and Battery
Double Sided Foam Tape
At first, I wasn't sure about the solder balls. Then I realized they were used to anchor the USB and Power Interface pins on the outside of the Headphone to the internal circuit board.
I had to used a solder iron to remove the solder balls, so that the internal interface circuit board could be removed. I had to also remove solder from the speaker wires to free up the internal circuit board.
Internal Circuit Board that interface Power and USB to the Headphones
The internal circuit board was also attached a MEMS Microphone that appeared to be monitoring the Speaker Chamber of the Headphone, since it was faced in
I had to remove the outside panel with 'R' on it with a Razor Knife to free the MEMS Microphone. Once the MEMS Microphone was freed, the interface board circuit could be pulled out
USB and Power (Charger) Interface
Sound Ports
MEMS Microphone from plastic collar in the Headphone
MEMS Microphone separated from the Interface Circuit Board when removed from the side of the Speaker Chamber
Closeup view of the Battery
Li-Ion 3.7V, 0.32Wh
The battery appears to be from VDL Electronics Co., Shenzhen, China
Closeup view of the Antenna/Touch Sensor side of the Main PCB
DSP Group - C2A1A Hybrid Active Noise Cancellation (ANC) Codec and Audio Digital Signal Processor (DSP)
651DF1M9 - Could not cross part number, but during a web search found out that it may be an integrated battery management IC
W25Q32JWUUIMTR- SPI FLASH 32Mb
MEMS Microphone Port
Closeup view of some of the components on the Antenna/Touch Sensor side of the Main PCB
Winbond-W25Q32JWUUIMTR SPI FLASH 32Mb
Battery side close up view of the Main PCB
AIROHA AB1552 - ARM Cortex M4/Bluetooth 5.0 Dual Mode
913 MPS1 MEMS Microphone. The Headphone uses three MEMS microphones with this part number
Could not cross the part number. If you know the part, please leave a comment below. The 2D bar code on the part reads as STM9135G15JAS011
Crystal Oscillator
Unknown component. Labelled B2A. Please leave a comment if you happen to know this component
Unknown component. Labelled SV4CP 240. Please leave a comment if you happen to know this component. Separated from PCB during teardown
Closeup view of some of the components on the Battery side of the Main PCB
4 comentários
same. can you post the teardown of the charging case?
Great teardown.
Steve Profit - Responder
