O que você precisa
Ferramentas
um parafuso Phillips PH1 localizado na parte traseira para remover a capa da bateria
Três parafusos Tri-point Y0 estão localizados sob a tampa da bateria
Em seguida, a placa frontal Vermelha/Branca sai pela parte da frente
A placa de circuito impresso é fixada em três suportes de plástico, usando apenas a pressão dos parafusos traseiros para mantê-la no lugar.
A placa de circuito impresso e o motor de vibração podem ser removidos com a menor pressão possível.
Botão de função localizado no centro
LED multicolorido ao lado do botão
18Comentários do guia
This post needs moar wisdom
Anybody able to spot a Pedometer?
There is no pedometer. It's just a Bluetooth clicker. Your phone's sensors track all movement.
What is the
"A1
HNG
SBJ"
chip in "step 6"?
I2C/SPI flash?
And.. what is in "Step 4" the chip? in between the capacitors and that "mostlikely MOSFETs for driving LEDs".
I'm looking at DA14580 modules on ebay:
http://www.ebay.com/sch/i.html?_from=R40...
And I tend to to say "let's try to clone this", the DA14580 has OTA programmable FLASH. :)
Last picture is most likely JTAG pogo contact points. For programming and testing. The board seems to be like 3-4+ layer board just based on the pictures. Also can't really tell you what chips those are with that quality of a picture. However the two little chips under the mounting hole on the picture in step 4 looks to be the DC Boost IC to keep constant voltage throughout the batteries life. The chip to the left of those boost converts is most likely the Bluetooth IC (just guessing by the location and the traces around it). Hope this helps :)
