Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Suzuki FA50 Moped, use o nosso manual de serviço.
  1. Suzuki FA50 Moped Throttle Cable Teardown, Suzuki FA50 Moped Throttle Cable Teardown: passo 1, imagem 1 %32
    • Here is the assembled throttle cable. It seems to be assembled correctly, but certainly does not function properly.
  2. Suzuki FA50 Moped Throttle Cable Teardown: passo 2, imagem 1 %32 Suzuki FA50 Moped Throttle Cable Teardown: passo 2, imagem 2 %32
    • The throttle parts.
    • The only logical way for me to assemble these parts were:
    • Insert needle into gold-colored cylinder.
    • Insert retaining clip on top of needle.
    • Then compress and insert the spring (see following steps on how the spring was inserted).
  3. Suzuki FA50 Moped Throttle Cable Teardown: passo 3, imagem 1 %32
    • The throttle cable without any parts.
    • The round, gray top screws into the carburetor.
  4. Suzuki FA50 Moped Throttle Cable Teardown: passo 4, imagem 1 %32
    • To assemble the throttle cable:
    • I first use a pair of needle-nose pliers to compress the spring as much as I can.
    • This allows me to insert the throttle cable into the gold-colored cylinder without having to meddle with the spring too much.
  5. Suzuki FA50 Moped Throttle Cable Teardown: passo 5, imagem 1 %32 Suzuki FA50 Moped Throttle Cable Teardown: passo 5, imagem 2 %32
    • I attach the throttle cable to the bottom of the gold cylinder and then route it through the cylinder's side slot.
    • The alternate view (picture 2) shows how everything looks internally.
    • After the throttle cable is in place, I let go of the spring into the cylinder.
  6. Suzuki FA50 Moped Throttle Cable Teardown: passo 6, imagem 1 %32 Suzuki FA50 Moped Throttle Cable Teardown: passo 6, imagem 2 %32
    • I'm simulating screwing on the throttle to the carburetor by compressing the gold cylinder against the gray cap. As you can see, the spring compresses, and the throttle cable pops outward.
    • When I twist the moped's throttle, the throttle cable goes inwards. I believe this is the desired action for the cable.
    • There are two problems, however:
    • Nothing pushes the throttle cable back out when I release the moped's throttle.
    • The throttle needle does not move, but to my understanding it should go upward when I apply the throttle.
    • Please check out my Answers question if you can help me solve this problem! Thanks a lot!
2 comentários
which way does you set the throttle when you put it in
ladell - Responder
It appears to be correctly assembled however the cable isn't bottomed out on the cup to allow for free movement, I think you may have put a flat spot in to the cable itself that's not allowing the cup to bottom out on it and giving you the return movement.
Ken James - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 42
Duração total: 12,869
