Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Strawberry, use o nosso manual de serviço.
  1. Strawberry Teardown, Seed debacle: passo 1, imagem 1 %32
    • We got our hands on the new and improved Strawberry!
    • We have the 200 seed version here.
    • We're excited to see whats new.
  2. Strawberry Teardown, The False Rumor, THANKS A LOT TIK-TOK! >:(: passo 2, imagem 1 %32 Strawberry Teardown, The False Rumor, THANKS A LOT TIK-TOK! >:(: passo 2, imagem 2 %32
    • So we heard rumors that we need to remove this seed to gain access to the "guts" of the strawberry.
    • Removing it, It shows that the rumor was False. (Don't count on rumors kids!)
  3. Strawberry Teardown, We're defeated: passo 3, imagem 1 %32
    • Defeated, We are getting restless.
  4. Strawberry Teardown, The clue: passo 4, imagem 1 %32 Strawberry Teardown, The clue: passo 4, imagem 2 %32 Strawberry Teardown, The clue: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • We found our first clue.
    • Use our tweezers, we can Forcefully remove the data connector.
    • With no avail, No way of getting in without any damage.
  5. Strawberry Teardown, We got in! (Time for Destruction >:D): passo 5, imagem 1 %32 Strawberry Teardown, We got in! (Time for Destruction >:D): passo 5, imagem 2 %32 Strawberry Teardown, We got in! (Time for Destruction >:D): passo 5, imagem 3 %32
    • This is the first guide featuring a swiss army knife.
    • We Got in :D
  6. Strawberry Teardown, Now what?: passo 6, imagem 1 %32 Strawberry Teardown, Now what?: passo 6, imagem 2 %32 Strawberry Teardown, Now what?: passo 6, imagem 3 %32
    • We stumbled upon a ominous gap.
    • Prying it, caused irreversible damage.
  7. Strawberry Teardown, The summary: passo 7, imagem 1 %32
    • Repairability - 3
    • You can't open it without damaging it... THUS you can't fix the internals of it. only the seeds on the outside.
    • But the seeds do most of the work
Ben Capehart
Membro desde: 06/09/21
7.341 Reputação
Autoria de 18 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 321
Autoria de 1.490 guias
17 comentários
Amazing!!!!!!!!!!!!😂
HelloMacOS - Responder
Lol 😂🤣🤣😂
Nana9833 - Responder
Very little detail in this tear down, you should at least confirm that the casing's colour is true and genuine RAL3018 (Google it!), or #fc5a8d if you want to be geeky. Also important: How long does it take, without ANY usage whatsoever, before it becomes unusable due to lack of any updates?
Mike - Responder
🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣 lol
Gabriel Knapp - Responder
is this teardown the same for a raspberry? Asking for a friend..
L'atelier Info - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 18
Últimos 30 dias: 54
Duração total: 2,880
