Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Speakal iPanda, use o nosso manual de serviço.
  1. Speakal iPanda Teardown, Speakal iPanda Teardown: passo 1, imagem 1 %32
    • The happy Panda
  2. Speakal iPanda Teardown: passo 2, imagem 1 %32 Speakal iPanda Teardown: passo 2, imagem 2 %32 Speakal iPanda Teardown: passo 2, imagem 3 %32
    • Flip it to find the screws.
    • Unscrew the four Phillips #0 screws.
  3. Speakal iPanda Teardown: passo 3, imagem 1 %32 Speakal iPanda Teardown: passo 3, imagem 2 %32
    • Be careful with the cables of the subwoofer.
  4. Speakal iPanda Teardown: passo 4, imagem 1 %32 Speakal iPanda Teardown: passo 4, imagem 2 %32
    • He look like this on his insides.
    • there is a little lock on the sides.
    • Don't forget these screws too.
  5. Speakal iPanda Teardown: passo 5, imagem 1 %32 Speakal iPanda Teardown: passo 5, imagem 2 %32
    • Opening the sandwich.
    • Don't forget the cables!
  6. Speakal iPanda Teardown: passo 6, imagem 1 %32 Speakal iPanda Teardown: passo 6, imagem 2 %32 Speakal iPanda Teardown: passo 6, imagem 3 %32
    • It doens't look like a panda anymore.
  7. Speakal iPanda Teardown: passo 7, imagem 1 %32
    • Removing the board, it's all done.
  8. Speakal iPanda Teardown: passo 8, imagem 1 %32 Speakal iPanda Teardown: passo 8, imagem 2 %32
    • Poor panda...
paulostool
Membro desde: 06/06/11
121 Reputação
Autoria de 1 guia
3 comentários
Hi!
I have just wondered about tweeter type.
I have a pig, bud one of it's tweeters is dead.
Do you have any idea how to get a replacement tweeter?
THX!!
sonofhoegaarden - Responder
Hello All,
Please can you assist me with sourcing a amplifier board for the Shox Panda as above in the panda tear down. My panda is supplying 12 Vots DC to the woofer. Thanks very much.
Peter Boucher - Responder
Hi Peter, you may consider swapping the actual CD7377CZ Audio Amp for a ST Microelectronics TDA7375V, and probably the RM2576-5.0 voltage regulator with a Texas Instruments LM2576-5.0, both of which are drop-in replacement (as parts are chinese knock-offs).
Cheers !
grogcw - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 5,047
