Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua PlayStation, use o nosso manual de serviço.
  1. Sony PlayStation SCPH-9002 Teardown, Sony PlayStation SCPH-9002 Teardown: passo 1, imagem 1 %32 Sony PlayStation SCPH-9002 Teardown, Sony PlayStation SCPH-9002 Teardown: passo 1, imagem 2 %32
    • Here's the PS1.
    • Turn the PS1 over and remove the six screws.
    • Note: part number +BV 3X14
  2. Sony PlayStation SCPH-9002 Teardown: passo 2, imagem 1 %32
    • Remove the top cover. It's very easy.
  3. Sony PlayStation SCPH-9002 Teardown: passo 3, imagem 1 %32
    • Disconnect both CD-ROM connectors.
    • CD connector one and the socket it connects to.
    • CD connector two and the socket it connects to.
    • Note: part number DEVICE OPTICAL KSM-440AEM
  4. Sony PlayStation SCPH-9002 Teardown: passo 4, imagem 1 %32 Sony PlayStation SCPH-9002 Teardown: passo 4, imagem 2 %32
    • Remove the CD-ROM reader. You should be able to pull it out gently, although you may have to wiggle it around a bit to loosen the rubber holders.
  5. Sony PlayStation SCPH-9002 Teardown: passo 5, imagem 1 %32
    • Detach both cables. They go to the power supply and to the memory cards and controller connectors.
  6. Sony PlayStation SCPH-9002 Teardown: passo 6, imagem 1 %32
    • Remove the four screws and the metal cover.
  7. Sony PlayStation SCPH-9002 Teardown: passo 7, imagem 1 %32 Sony PlayStation SCPH-9002 Teardown: passo 7, imagem 2 %32
    • Now you have the motherboard!
    • And the power supply.
    • Remove the four screws from the motherboard and the power supply.
  8. Sony PlayStation SCPH-9002 Teardown: passo 8, imagem 1 %32
    • Once the screws are removed, remove the power supply.
  9. Sony PlayStation SCPH-9002 Teardown: passo 9, imagem 1 %32
    • Remove the motherboard, and both of the screws from the memory card/ controller connection mechanism.
  10. Sony PlayStation SCPH-9002 Teardown: passo 10, imagem 1 %32
    • Now, you have all your PlayStation 1 parts!
    • Main Board
    • Lower Casing
    • EMI Shield
    • Power Supply
    • Disk Reader
    • Memory Card/ Controller Mechanism
imacg517
Membro desde: 05/06/10
182 Reputação
Autoria de 1 guia
Um comentário
That’s a PAL PS1. May be different from NTSC models.
Daniel Powers - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 29
Últimos 30 dias: 131
Duração total: 28,253
