Introdução
In this guide I will show you how to teardown Sony INZONE M3 monitor. The most difficult part is the
Overview of Sony 27" INZONE M3 Full HD HDR 240Hz Gaming Monitor. Place the display panel on a cushioned, flat surface.
Tools: iFixit Picks and Opening Picks
Beware of the snap-fits, because they are fragile. Leave the picks in between so they won't snap again.
Much effort is required, and this is the most difficult & time-consuming step.
Refer to 3rd picture for the position of snap-fits. Twist around snap-fits area to unlock them.
The joystick comes with a direction indicator: BTM for facing bottom.
Remove using screws
Remove two screws
Remove tape
Beware of static on your hands. Release it before touching the metal sheet.
Remove plug;
remove 6 screws on the front;
remove a black screw fixing the silicon grease radiator on the back
When assembling back, it is recommended to fully detach the radiator and mount onto the sheet metal first, to avoid positioning issues.
Remove bottom sticker
Remove 7 screws on the middle frame
A smaller size screw head is used.
Remove all the stickers and unscrew 4 screws on the PCB
Another 3 screws hidden under tape on middle frame.
Detach bottom decoration strip
And then detach bottom PCB, with magnetic parts
