Ir para o conteúdo principal
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Sony INZONE M3, use o nosso manual de serviço.
  1. Sony INZONE M3 Teardown, Overview: passo 1, imagem 1 %32
    • Overview of Sony 27" INZONE M3 Full HD HDR 240Hz Gaming Monitor. Place the display panel on a cushioned, flat surface.
  2. Sony INZONE M3 Teardown, Remove mounting screws: passo 2, imagem 1 %32
    • Remove the screws on VESA interface
  3. Sony INZONE M3 Teardown, Detach back panel: passo 3, imagem 1 %32 Sony INZONE M3 Teardown, Detach back panel: passo 3, imagem 2 %32 Sony INZONE M3 Teardown, Detach back panel: passo 3, imagem 3 %32
    • Tools: iFixit Picks and Opening Picks
    • Beware of the snap-fits, because they are fragile. Leave the picks in between so they won't snap again.
    • Much effort is required, and this is the most difficult & time-consuming step.
    • Refer to 3rd picture for the position of snap-fits. Twist around snap-fits area to unlock them.
  4. Sony INZONE M3 Teardown, Unplug wires for speaker, main PCB and joystick PCB: passo 4, imagem 1 %32 Sony INZONE M3 Teardown, Unplug wires for speaker, main PCB and joystick PCB: passo 4, imagem 2 %32 Sony INZONE M3 Teardown, Unplug wires for speaker, main PCB and joystick PCB: passo 4, imagem 3 %32
    • Unplug.
  5. Sony INZONE M3 Teardown, Remove control joystick: passo 5, imagem 1 %32 Sony INZONE M3 Teardown, Remove control joystick: passo 5, imagem 2 %32 Sony INZONE M3 Teardown, Remove control joystick: passo 5, imagem 3 %32
    • The joystick comes with a direction indicator: BTM for facing bottom.
    • Remove using screws
  6. Sony INZONE M3 Teardown, Detach metal sheet: passo 6, imagem 1 %32 Sony INZONE M3 Teardown, Detach metal sheet: passo 6, imagem 2 %32 Sony INZONE M3 Teardown, Detach metal sheet: passo 6, imagem 3 %32
    • Remove two screws
    • Remove tape
    • Beware of static on your hands. Release it before touching the metal sheet.
  7. Sony INZONE M3 Teardown, Detach main PCB board: passo 7, imagem 1 %32 Sony INZONE M3 Teardown, Detach main PCB board: passo 7, imagem 2 %32 Sony INZONE M3 Teardown, Detach main PCB board: passo 7, imagem 3 %32
    • Remove plug;
    • remove 6 screws on the front;
    • remove a black screw fixing the silicon grease radiator on the back
  8. Sony INZONE M3 Teardown, Main PCB board: passo 8, imagem 1 %32
    • When assembling back, it is recommended to fully detach the radiator and mount onto the sheet metal first, to avoid positioning issues.
  9. Sony INZONE M3 Teardown, Remove middle frame: passo 9, imagem 1 %32 Sony INZONE M3 Teardown, Remove middle frame: passo 9, imagem 2 %32 Sony INZONE M3 Teardown, Remove middle frame: passo 9, imagem 3 %32
    • Remove bottom sticker
    • Remove 7 screws on the middle frame
    • A smaller size screw head is used.
  10. Sony INZONE M3 Teardown, Almost there! Detach control PCB: passo 10, imagem 1 %32 Sony INZONE M3 Teardown, Almost there! Detach control PCB: passo 10, imagem 2 %32 Sony INZONE M3 Teardown, Almost there! Detach control PCB: passo 10, imagem 3 %32
    • Remove all the stickers and unscrew 4 screws on the PCB
    • Another 3 screws hidden under tape on middle frame.
  11. Sony INZONE M3 Teardown, Detach bottom decoration strip: passo 11, imagem 1 %32 Sony INZONE M3 Teardown, Detach bottom decoration strip: passo 11, imagem 2 %32
    • Detach bottom decoration strip
    • And then detach bottom PCB, with magnetic parts
  12. Sony INZONE M3 Teardown, Finish: passo 12, imagem 1 %32
    • Full display of all parts.
Jerry LIU
Membro desde: 01/23/25
205 Reputação
Autoria de 1 guia
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 41
Ao todo: 182
