Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Sony Ericsson K750i, use o nosso manual de serviço.
  1. Sony Ericsson K750i Teardown, Battery Cover: passo 1, imagem 1 %32
    • Remove the battery cover.
    • Press down firmly with your thumb and slide the cover back.
  2. Sony Ericsson K750i Teardown, Back Casing: passo 2, imagem 1 %32
    • Remove two Phillips #0 screws from the battery chamber.
    • Remove two Torx T6 screws from the battery chamber.
  3. Sony Ericsson K750i Teardown: passo 3, imagem 1 %32
    • Gently pry off the back casing.
    • Work an opening tool around the entire seam before attempting to pull off the casing. This action will reduce the chance of cracking the casing.
  4. Sony Ericsson K750i Teardown: passo 4, imagem 1 %32
    • Remove the casing to expose the camera's components.
  5. Sony Ericsson K750i Teardown, Keypad: passo 5, imagem 1 %32
    • Gently pry open the front casing by working an opening tool along the entire seam.
  6. Sony Ericsson K750i Teardown: passo 6, imagem 1 %32
    • Remove the front casing by gently lifting it from the phone.
    • Be careful not to pull off any other delicate pieces.
  7. Sony Ericsson K750i Teardown: passo 7, imagem 1 %32 Sony Ericsson K750i Teardown: passo 7, imagem 2 %32
    • Remove the keypad.
    • The LCD screen is very fragile. Be careful not to catch the keypad on it while removing.
  8. Sony Ericsson K750i Teardown, LCD Screen: passo 8, imagem 1 %32
    • Remove the screws holding the screen in place.
  9. Sony Ericsson K750i Teardown: passo 9, imagem 1 %32
    • Gently lift the base of the keypad to remove it.
  10. Sony Ericsson K750i Teardown: passo 10, imagem 1 %32
    • Gently pull up the green film, avoiding the joystick.
    • The LCD screen will be attached to this film and come off with it.
  11. Sony Ericsson K750i Teardown, Sony Ericsson K750i Teardown: passo 11, imagem 1 %32
    • Remove the back cover from the phone.
    • Gently slide the ribbon out of its connection.
  12. Sony Ericsson K750i Teardown: passo 12, imagem 1 %32 Sony Ericsson K750i Teardown: passo 12, imagem 2 %32
    • Lift the motherboard out of the phone.
    • The ribbon is fragile so work the motherboard off around the ribbon to prevent damage.
  13. Sony Ericsson K750i Teardown: passo 13, imagem 1 %32 Sony Ericsson K750i Teardown: passo 13, imagem 2 %32
    • Pry off the microchip that is located below the ribbon.
  14. Sony Ericsson K750i Teardown: passo 14, imagem 1 %32 Sony Ericsson K750i Teardown: passo 14, imagem 2 %32
    • Lift out the plastic support to complete the teardown.
Abby Evers
Membro desde: 10/04/11
202 Reputação
Autoria de 6 guias
Equipe
UW Stout, Team 1-6, Zhou Fall 2011 Membro de UW Stout, Team 1-6, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G6
Membros da 4
Autoria de 12 guias
Um comentário
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 38
Duração total: 12,531
