O que você precisa
Remove the battery cover.
Press down firmly with your thumb and slide the cover back.
Remove two Phillips #0 screws from the battery chamber.
Remove two Torx T6 screws from the battery chamber.
Gently pry open the front casing by working an opening tool along the entire seam.
Remove the back cover from the phone.
Gently slide the ribbon out of its connection.
