I will teach you how to deconstruct a DVD-ROM unit into it's base assembly and then show what many people use to build a burning laser.
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Toshiba Samsung Storage DVD Writer(TS-H653), use o nosso manual de serviço.
Check for any remaining screws around the edge of the board, if there are none apparent double check the ribbons and the slide the board back until it slides free
To remove the pole that was in the picture before it was removed, push down on the spring with a screw at one end removed the tilt one end up and remove
To remove toothed gears push the clip inside the spire in the middle of the gear, and maintaining pressure on the clip pull away the gear
Apply the same technique as in picture 2 but with the clip in picture 3
