Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Sony D-822K Car Discman, use o nosso manual de serviço.
  1. Sony D-822K Car Discman Teardown, Sony D-822K Car Discman Teardown: passo 1, imagem 1 %32
    • Obtain a D822-K Discman and remote. True, it has DSP and Surround Sound, but the 90's have come and gone. It's okay to take it apart.
  2. Sony D-822K Car Discman Teardown: passo 2, imagem 1 %32
    • Position unit so that the bottom is facing up. Remove the 6 screws.
    • Hold top and bottom of unit together as you turn the unit over, bottom facing down. Use caution; the upper and lower case, along with circuit board are now loose.
    • Watch out for the AVLS and illumination switches, they love to disappear when unsupervised. Remove top of case.
  3. Sony D-822K Car Discman Teardown: passo 3, imagem 1 %32 Sony D-822K Car Discman Teardown: passo 3, imagem 2 %32 Sony D-822K Car Discman Teardown: passo 3, imagem 3 %32
    • Removing the CD reader: Gently pull all 3 rubber grommets sideways, away from the CD reader.
    • Slide edge of ribbon cable connector towards ribbon cable to disengage.
    • Unplug the red, white, and blue plugs from the circuit board.
  4. Sony D-822K Car Discman Teardown: passo 4, imagem 1 %32 Sony D-822K Car Discman Teardown: passo 4, imagem 2 %32
    • Observation: This is the Hydro Suspension system...really.
  5. Sony D-822K Car Discman Teardown: passo 5, imagem 1 %32 Sony D-822K Car Discman Teardown: passo 5, imagem 2 %32 Sony D-822K Car Discman Teardown: passo 5, imagem 3 %32
    • Remove circuit board
    • Notice the dual-color light modules. (I temporarily connected the power to show off the lights)
  6. Sony D-822K Car Discman Teardown: passo 6, imagem 1 %32
    • Disconnect tailpiece, and power supply.
  7. Sony D-822K Car Discman Teardown: passo 7, imagem 1 %32 Sony D-822K Car Discman Teardown: passo 7, imagem 2 %32
    • Remote: Remove the 3 screws from the bottom. Pull apart.
    • The function buttons have a neat overlay design.
  8. Sony D-822K Car Discman Teardown: passo 8, imagem 1 %32
    • Completely disassembled. The illumination button was lost for two weeks after reassembling... but who uses amber lights anymore?
modem21
Membro desde: 10/09/09
84 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 26
Duração total: 18,063
