Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Sky TV Remote, use o nosso manual de serviço.
  1. Sky TV Remote Teardown, Sky TV Remote Teardown: passo 1, imagem 1 %32 Sky TV Remote Teardown, Sky TV Remote Teardown: passo 1, imagem 2 %32 Sky TV Remote Teardown, Sky TV Remote Teardown: passo 1, imagem 3 %32
    • This is it. Well, this is it in a functional state.
    • Remove the batteries before starting!
  2. Sky TV Remote Teardown: passo 2, imagem 1 %32 Sky TV Remote Teardown: passo 2, imagem 2 %32 Sky TV Remote Teardown: passo 2, imagem 3 %32
    • Use a Philips head screwdriver to remove this screw
    • Use a spudger to unlock all the tabs around the sides, start at the bottom
    • Work your way all the way around the remote, this is flippin' tricky.
    • Brute force is compulsory.
  3. Sky TV Remote Teardown: passo 3, imagem 1 %32 Sky TV Remote Teardown: passo 3, imagem 2 %32 Sky TV Remote Teardown: passo 3, imagem 3 %32
    • After all the tabs are off, the body should just fall away leaving the buttons, the circuit board, the case and the black infra-red bit at the end.
    • Ta-daa!
3 comentários
On early models theres a second screw under the black infa red filter. If it doesnt come apart as above, ther black filter is held on by two tabs. On the battery compartment side, the black plastic nearest the battery, wedge a small screwdriver between the body and the pastic and the filter should slide away revealing a second screw!
tim - Responder
How do I clean? Buttons not making electrical connection. New remots don't recognize my TV.
Ronald Welemin - Responder
Also, is there a product that I can put on the connection buttons to improve contact?
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 27
Últimos 30 dias: 216
Duração total: 17,037
